KC868-A8 - question regarding safety shutdown
1. But what does the board do if the Lan connection is gone. Do the relais and states just stay as they are or ist there also a way to shut all relais down ?
-->relais and states just stay as they are, no changes, will not all off.
2. What do you mean by use a digital input to turn off all relais (where should the signal come from)? How could that be realized?
--> my means, digital input can connect with push button, define any fucntion you wanted.
3. My idea could be to built something like a watchdog -> for example send e.g. every 5 seconds a "ping" to the KC868 board. And if this "ping" is not there the board shuts down all relais. Is that possible (maybe also via ethernet) ? Perhaps the same could be done the other way round.
--> do you want auto turn all relay off when network disconnected?
4. My idea could be to built something like a watchdog -> for example send e.g. every 5 seconds a "ping" to the KC868 board. And if this "ping" is not there the board shuts down all relais. Is that possible (maybe also via ethernet) ? Perhaps the same could be done the other way round.
--> what software you will use? home assistant? if you have a server, you can do that.
RE: KC868-A8 - question regarding safety shutdown - by admin - 08-22-2023, 06:25 AM
