KC868-H32B Pro + KC868-AK work with multi switch panel control same relay
(10-17-2023, 11:33 AM)Nikhil Wrote:
(09-30-2023, 11:28 PM)admin Wrote: if you want use use KC868-AK work with KC868-H32BS, need config AK board firstly, here is details:
https://www.kincony.com/how-to-use-kc868...board.html
Done everything as said in document. My H32BS relay works when using waveshare rs485 gateway. But when I tried connecting gateway to 868Ak, i cannot get any data in node red when button is pressed. How to make sure if ak board is ok
H32BS firmware is H32BS_V2.10SP
Does it need update?
I am attaching configuration pics for h32bs and 868ak
Show me your connections  about KC868-AK and KC868-H32BS.I want to make sure the connection is OK.
RE: KC868-H32B Pro + KC868-AK work with multi switch panel control same relay - by KinCony Support - 10-18-2023, 01:59 AM
