11-10-2023, 11:05 AM
Hello everyone, im new here and i recently bought KC868-A16S, i already flashed the new firmware: Software Version v2.1.9
Build Date Sep 26 2023 14:42:27 and i can connect to Kincony Admin page and can control the output from the MONITOR.
My problem is i cannot connect the board to HOME ASSISTANT, everytime I install the yaml file this error comes:
"< INFO ESPHome 2023.10.6
INFO Reading configuration /config/esphome/a16s.yaml...
WARNING GPIO5 is a Strapping PIN and should be avoided.
See https://esphome.io/guides/faq.html#why-a...pping-pins
INFO Generating C++ source...
INFO Core config or version changed, cleaning build files...
INFO Deleting /data/build/kc868-a16s/.pioenvs
INFO Compiling app...
Processing kc868-a16s (board: esp32dev; framework: arduino; platform: platformio/espressif32@5.4.0)
Platform Manager: Installing platformio/espressif32 @ 5.4.0
INFO Installing platformio/espressif32 @ 5.4.0
WARNING Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NameResolutionError("<urllib3.connection.HTTPSConnection object at 0x7f0e82c235b0>: Failed to resolve 'api.registry.platformio.org' ([Errno -3] Temporary failure in name resolution)")': /v3/packages/platformio/platform/espressif32 >>
its API related i dont know how. please help me.. =)
