03-09-2022, 11:22 AM
Help needed/wanted?
03-09-2022, 11:35 AM
there are H32L and H32B all have broken?
03-09-2022, 11:37 AM
it have overload, we suggest you replace the PCB, if you want to try fix it. you can use wire welder with bad pin, because your PCB line is already disconnected.
03-10-2022, 12:49 PM
Hello Admin,
Many thanks, My own fault, have been give a little money off my wife to buy another, However this time I'm going to put full protection in, I do have a few questions first, as designing my system now. Do i need contactors? Gary
03-10-2022, 12:57 PM
i suggest you chose H32BS + KC868-E16 extend relay module, it's the most stable way. if your load current >10A , suggest add contactor, contactor is most safety. I think you very love your wife
03-10-2022, 01:33 PM
hello Admin,
Yes a wise and lovely wife. 谢谢 ![]() If I list out my requirements and plan can you help me put together a DIY kit? Many Thanks Gary
03-10-2022, 01:48 PM
ok, you can list.
03-10-2022, 02:57 PM
(03-10-2022, 01:33 PM)gay Wrote: hello Admin, Hello Admin, The following needs to be on 6a circuit for UK Regulations. (So my electrician says, please advise) 8no x lighting rows with 3x 220v spotlights in each row 40Ma 4.7w gu10 1no x lighting rows with 3x 220v down-lights in each row 76Ma 9w screw fittings The needs to be on 16amp circuit for UK Regulations. (So my electrician says, please advise) 5 x 230v Double Sockets 13amp or lower appliances Although have asked for KC868-H32BS, to Start I will only have 14 in use, The rest will be used at a later date. I already have your switch terminal board v2.1 (32 channel), this needs to be taken into account. I already Have steel distribution box (20cm x 50cm x 50cm) Please add what you think to fully protect it please, below is a list i have started. KC868-H32BS - Need x 1no DC 12v power supply - Need x 1no Kincony 8CH RC Absorption Snubber -Need x 2no kind regards Gary
03-11-2022, 12:31 AM
H32BS already integrated "switch terminal board", so not need use "switch terminal board" again, your wall switch panel's wire connect to H32BS directly. if you use H32BS must need add KC868-E16 extend relay module or DC contact. Because H32BS It adopts the design of separating high voltage from low voltage, which has very good stability. If the relay is broken, because the relay is removable, it is easy to replace and repair by yourself.
if use H32BS, not need add RC snubber, because extend relay or contact is "DC", no interference signal.
03-11-2022, 10:40 AM
(03-11-2022, 12:31 AM)admin Wrote: H32BS already integrated "switch terminal board", so not need use "switch terminal board" again, your wall switch panel's wire connect to H32BS directly. if you use H32BS must need add KC868-E16 extend relay module or DC contact. Because H32BS It adopts the design of separating high voltage from low voltage, which has very good stability. If the relay is broken, because the relay is removable, it is easy to replace and repair by yourself. Hi Admin Have you a link to DIY bundle for H32BS with KC868-E16 please? (My wife insists again) ![]() Gary |
« Next Oldest | Next Newest »
Users browsing this thread: |
