How to use tasmota for KC868-A32 via PCF8574 IIC extend GPIO
#11
(07-28-2022, 11:17 AM)admin Wrote: A32 support tasmota, but tasmota support input+output total=32 channel , such as you can use 32 channel for output, or 16 channel input and 16 channel output. just input ports + output ports <=MAX 32 channels.
Hi! Could you elaborate on that, cause I didn't exactly understand. Can the KC868-A32  that is flashed with Tasmota with the template that you provide on it's page work normally in Home assistant, as a 32 channel switch? What exactly is the issue with MQTT that petez69 mentions? Will it update the status of every switch in HA for on/off?
P.S.: I found the answer in another post.
