KC868-H32B V4.29 new firmware update
#11
Hi,
I also get wrong username and password error, when I try to update firmware on 4.29. Bootloader and everything went ok, I get the web page of the controller (admin/admin does not work), also all the switch terminal board inputs work.
Also I noticed when I try to switch the relays with my previeos configuration in Node-Red, that the controller is very slow, and responds to commands with a delay or does not respond at all.
With 4.20 fw all worked ok. Every week or so I had to reset the controller, because it did not respond on my commands - switch terminal board commands and HA(node red) commands.
if you updated newest firmware, we suggest integrate to HA with MQTT, it's very stable, not need to use Node-Red work with HA. only HA is enough.
I will do that.
But what about the password error and about the controller not responding?
thank you.
after update to newest verison, user name and password all default set to "admin" , "admin".
[Image: wCznWqm]
After update to 4.29
In my case didn't work admin/admin also after an update. I had to reset to default settings.
new firmware use ethernet button for reset will set user name and password to "admin" - "admin"
Ok, thank you.
What is the correct procedure for reset, and could you point me to the correct button for the reset.
Thank you.
Hold on "Ethernet Mode" button, when the [yellow and white LED] all is ON, release it, then work mode in “UDP” and IP by DHCP mode and password reset to "admin". user name fixed by "admin", never changed.
OK, now after reset it is working.
Thank you.
