Smart Home project
#11
(10-30-2024, 11:28 PM)admin Wrote: 1. this is KCS firmware for KC868-A64: https://www.kincony.com/forum/showthread.php?tid=3504
Do you download this version?
2. you can also config by ESPHome for your KC868-A64
3. can you draw a diagram on paper, how you connect KC868-A64 with KC868-E16v2 board.
1. Yes i used this version.
2. yes we know, it will be done later.
3. below
on picture you have only 2 E16v2
next 2 E16v2 is conected the same and powered by second power supply the same way.
if you use two power supply, you should connect two power supply's GROUND together. why not use one big current power supply? such as DC12V 7A
(10-31-2024, 01:48 PM)admin Wrote: if you use two power supply, you should connect two power supply's GROUND together. why not use one big current power supply? such as DC12V 7A
Yes i think it will resolve this issue
How much power I should delivery for a64 + 4 e16?
4x 16 x 0,5w =32 W
A64 20 w
60 w?
Why you propose 100w ? In our previous conversation I asked about power supply and you said that it’s ok to power it up like this. If one bigger will be better I will change .
but still it’s super slow and sometime not refreshing the status ?
4x 16 x 0,5w =32 W
A64 20 w
60 w?
Why you propose 150w ? In our previous conversation I asked about power supply and you said that it’s ok to power it up like this. If one bigger will be better I will change .
because of all relay ALL ON at the same time, instantaneous current is very high. But now just connect your two power supply GROUND together for testing firstly.
