11-27-2023, 04:02 PM
Kincony and Which warm flloor termostat would be better?
11-27-2023, 10:39 PM
your load connect to KC868-H32B Pro, KC868-AK also connect to KC868-H32B Pro for manual control way.
Online Store: https://shop.kincony.com Alibaba Store: https://kincony.en.alibaba.com/ (11-27-2023, 10:39 PM)admin Wrote: your load connect to KC868-H32B Pro, KC868-AK also connect to KC868-H32B Pro for manual control way. @admin: you have to take a look at underfloor heating solution in Europe, and implement something like that in your devices. Please see example: https://saluscontrols.com/gb/ Also try to implement a solution with zigbee termostats, in a iftt scenario, that work without internet. Also consider using ssr relays, as they are silent. Thanks. Consider using this kind of termostat (or any zigbee termostat) : https://www.aliexpress.com/item/10050064...Redirect=y
02-19-2024, 10:51 PM
your second link is a zigbee sensor, not termostat . do you want a zigbee sensor can automatic control another relay board?
Online Store: https://shop.kincony.com Alibaba Store: https://kincony.en.alibaba.com/ (02-19-2024, 10:51 PM)admin Wrote: your second link is a zigbee sensor, not termostat . do you want a zigbee sensor can automatic control another relay board? Consider a master relay board that has remote zigbee sensors that can control the on/off function for specific relays that control the underfloor heating colils and the gas boiler and pump. Thanks. (02-22-2024, 07:37 PM)Nike78 Wrote:(02-19-2024, 10:51 PM)admin Wrote: your second link is a zigbee sensor, not termostat . do you want a zigbee sensor can automatic control another relay board? Something like this: https://www.aliexpress.com/item/10050058...ry_from%3A |
« Next Oldest | Next Newest »
