ifttt program problem
#11
(12-18-2020, 01:05 PM)admin Wrote: I think we can change the action OPEN/CLOSE by relay ON/OFF, that will be easy to understand, not use OPEN/CLOSE words.
As promised, after detail check look IFTTT not defined on any case what is subject of logical operation. It is just same as most other programming language: IF .. Then.
In this case your idea is good use On/Off, of course in meaning energized the relay coil.
On - relay coil voltage present
Off - relay coil voltage not present
Yes, ON - given relay coil power for DC12V OFF- not given relay coil power for DC12V
(12-19-2020, 03:11 AM)admin Wrote: Yes, ON - given relay coil power for DC12V  OFF- not given relay coil power for DC12V
Thanks, it will be more clear to all users.
next version will update this.
2 Guest(s)
