sample code to receive http get
#11
ok, good.
(12-30-2025, 04:53 AM)admin Wrote: ok, good.
One more question.
I've tried to use (TLS/SSL) MQTTS://nnn.nnn.nnn.nnn, Port  8883.
It seem cannot connected to the Broker until I put CA file on the F16.
How to implement MQTTS on the devices F16?
it only support MQTT, not MQTTS.
(01-02-2026, 09:57 AM)admin Wrote: it only support MQTT, not MQTTS.
do you have a plan to upgrade the firmware that will support MQTTS or WebSocket (WS & WSS)?
do you use cloud server suppiler's mqtts or use your own SSL certificate?
(03-05-2026, 03:53 AM)admin Wrote: do you use cloud server suppiler's mqtts or use your own SSL certificate?
I plan to use my own server ssl certificate.
example: wss://sub.domain.com port 443 with user & password
do you using F16 controller for this function? i can make a new firmware add the TLS for you testing.
(03-07-2026, 11:00 PM)admin Wrote: do you using F16 controller for this function? i can make a new firmware add the TLS for you testing.
yes, am using F16 ESP32-S3.
Now, i am waiting.
Just info when yo finish it.
Thank you,
Now, i am waiting.
For additional info, we already tested our mqtt server using websocket over https protocol (wss://sub.domain.com:443).
it is succesfully connected.
Thank you,
you can test with this new firmware.
.zip   KCS_F16_V3.23.1_beta_20260308-014209.zip (Size: 1.14 MB / Downloads: 330)
