Threads: 1,560
you can check with ESP32S3 module datasheet.
Threads: 5
After working on trying to get my Z1 connected to my wireless.. I have failed after nearly 2 months now.. According to the ESP32S3 datasheets, it's 2.4mHz only. And it does support WPA2-PSK/WPA2-Enterprise, and WPA3-PSK/WPA3-Enterprise encyption.
My router is a Peplink Cellular Wi-Fi Router MAX BR1 Mini. And WILL NOT CONNECT TO IT.
So, my fix is to buy another AP point, and get that working. Which works as of now. But I have to run two WiFi AP points in my Van.
I'll keep working with it, as I blame the Peplink.
Peplink has been working with me, however, after not hearing from them for over 1 month now, I think they have given up on helping me out.
Just an FYI. Thank you for your time.
ps. Will you be creating a Z1 unit, with an Ethernet jack? An Ethernet jack would solve all my issues.
Thanks
Threads: 1,560
what resource you have used? zigbee? or ?
Threads: 5
Resource? I'm trying to connect via WiFi, and I'm ONLY trying to connect at this moment. I haven't got to set up the whole unit, untill it's connected to my WiFi.
Threads: 1,560
we have many ethernet board, i just want to know, if you connect Z1 by ethernet, what you want do? such as connect with a zigbee sensor? receive RF signal? or send IR signal?
Threads: 1,560
if you want use IR and RF in home assistant, need learn signal firstly. then enable mqtt auto discovery for home assistsant.
