Threads: 1,531
already repied you. other brand driver can't sure 100%. if kincony driver have issue, we can refund to you.
Threads: 1,531
the driver used that we have bought 3 years ago.
Threads: 1
Having same issue here. DM16 output is 0,6-0,7V on turned off channel and do not turn of my Meanwell ELG- 200 series driver which has specific option dim-to-off function.
Also, dimming in HA from 0-35% shows the same current 0,6-0,7V. Just above ~40% starts to raise. What solution can be done here?
All house is equipped with this series drivers, so the answer to buy Kincony drivers is not welcome.
Threads: 1,531
This is a compatibility issue with the drive, and the drive must be replaced. Alternatively, you can connect a diode in series with the 0-10V output terminal for voltage reduction.
Threads: 1
06-26-2026, 06:59 AM
(This post was last modified: 06-26-2026, 07:49 AM by VKAN.)
I just tried KCS v3 firm in DM16, there current output is nice, follows preset percentage. (when in HA from 0-40% output is 0,6V).
But Dim to off is not working as well in KCS. I added diode in series 1N4001, and output with preset 0% gets 1,12V. (without diode 0,62V).
(BTW, unplugged driver 0-10 line shows 10,12V)
Update. Solved with Gemini - 1 kΩ resistor in parallel.
