KC868-M16v2 configure yaml for ESPhome
#51
(04-01-2025, 11:59 PM)admin Wrote:
(02-27-2025, 11:52 PM)admin Wrote: you can try to test this code.
esp32:
  board: esp32dev
  framework:
    type: arduino
external_components:
  - source:
      type: git
      url: https://github.com/hzkincony/esphome-zmpt101b
    refresh: 1min
  encryption:
    key: "D69bY/GXlmjYkovak6WIhgmbOH8vwyqvMxIHBriYoaY="
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  sda: 4
  scl: 5
cd74hc4067:
  - id: cd74hc4067_1
    pin_s0: 32
    pin_s1: 33
    pin_s2: 13
    pin_s3: 16
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "T: %.1f°C", id(temperature).state);
      it.printf(0, 20, id(roboto), "H: %.1f%%", id(humidity).state);
      it.printf(0, 40, id(roboto), "AC:%.1fV", id(voltage_1).state);
  - platform: zmpt101b
    name: "m16--AI zmpt 34"
    adc_pin: 34
    unit_of_measurement: V
    accuracy_decimals: 1
    state_class: "measurement"
    name: "m16--AI zmpt 36"
    adc_pin: 36
    name: "m16--AI zmpt 39"
    adc_pin: 39
  - platform: sht3xd
    temperature:
      name: "sht Temperature"
    humidity:
      name: "sht Humidity"
    address: 0x44
    update_interval: 5s
  - platform: adc
    pin: 35
    update_interval: never
    attenuation: 11db
  # - platform: adc
  #   name: "m16--AI-1"
  #   pin: 36
  #   id: adc36
  #   update_interval: 60s
  #   attenuation: 11db
  # - platform: adc
  #   pin: 34
  #   name: "m16--AI-2"
  #   id: adc34
  #   attenuation: 11db
  # - platform: adc
  #   pin: 39
  #   name: "m16--AI-3"
  #   id: adc39
  #   attenuation: 11db
  - platform: cd74hc4067
    sensor: adc35
    number: 1
    sensor: adc35
    number: 2
    sensor: adc35
    number: 3
    sensor: adc35
    number: 4
    sensor: adc35
    number: 5
    sensor: adc35
    number: 6
    sensor: adc35
    number: 7
    sensor: adc35
    number: 8
    sensor: adc35
    number: 9
    sensor: adc35
    number: 10
    sensor: adc35
    number: 11
    sensor: adc35
    number: 12
    sensor: adc35
    number: 13
    sensor: adc35
    number: 14
    sensor: adc35
    number: 15
    sensor: adc35
  - platform: ct_clamp
    sensor: ai1
    name: "Measured Current-1"
    update_interval: 5s
    filters:
      - calibrate_linear:
          # Measured value of 0 maps to 0A
          - 0.0034 -> 0
          # Known load: 4.0A
          # Value shown in logs: 0.1333A
          - 0.31749 -> 8.95608
  - platform: template
    lambda: return id(Measured_Current_1).state * id(voltage_1).state;
    device_class: power
    unit_of_measurement: 'W'
  - platform: total_daily_energy
    name: "Total Daily Energy1"
    power_id: power1
    filters:
        - multiply: 0.001
    unit_of_measurement: kWh
    accuracy_decimals: 3
    icon: mdi:clock-alert
    device_class: energy
    sensor: ai2
    name: "Measured Current-2"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai3
    name: "Measured Current-3"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai4
    name: "Measured Current-4"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai5
    name: "Measured Current-5"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai6
    name: "Measured Current-6"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai7
    name: "Measured Current-7"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai8
    name: "Measured Current-8"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai9
    name: "Measured Current-9"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai10
    name: "Measured Current-10"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai11
    name: "Measured Current-11"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai12
    name: "Measured Current-12"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai13
    name: "Measured Current-13"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai14
    name: "Measured Current-14"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai15
    name: "Measured Current-15"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai16
    name: "Measured Current-16"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
time:
  - platform: sntp
yaml file download:
just do as this yaml file, it have updated for newest esphome 2025.2.
just use this yaml file, you have tested two week ago.
I already had that file but I reloaded it anyway. Unfortunately I still can't see the card...is a reset possible?
no reset function. just ERASER ESP32 chip, then re download firmware again.
the log returns this:
"INFO ESPHome 2025.3.3 INFO Reading configuration /config/esphome/m16.yaml... INFO Updating https://github.com/hzkincony/esphome-zmpt101b@None WARNING GPIO5 is a strapping PIN and should only be used for I/O with care. Attaching external pullup/down resistors to strapping pins can cause unexpected failures. See https://esphome.io/guides/faq.html#why-a...pping-pins WARNING `attenuation: 11db` is deprecated, use `attenuation: 12db` instead INFO Detected timezone 'Europe/Rome' INFO Starting log output from m16.local using esphome API WARNING Can't connect to ESPHome API for m16.local: Timeout while resolving IP address for ['m16.local'] (ResolveTimeoutAPIError) INFO Trying to connect to m16.local in the background"
and the new log:
"INFO ESPHome 2025.3.3 INFO Reading configuration /config/esphome/m16.yaml... WARNING GPIO5 is a strapping PIN and should only be used for I/O with care. Attaching external pullup/down resistors to strapping pins can cause unexpected failures. See https://esphome.io/guides/faq.html#why-a...pping-pins WARNING `attenuation: 11db` is deprecated, use `attenuation: 12db` instead INFO Detected timezone 'Europe/Rome' INFO Starting log output from 192.168.0.15 using esphome API WARNING Can't connect to ESPHome API for m16 @ 192.168.0.15: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.0.15', port=6053))]: [Errno 111] Connect call failed ('192.168.0.15', 6053) (SocketAPIError) INFO Trying to connect to m16 @ 192.168.0.15 in the background"
I tried via wifi and it worked right away. What can I do to fix via cable?
admin, can you help me?
do your M16v2 board and your home assistant server connect with same router by ethernet cable?
yes, home assistant is on a pc connected via cable. I also have other peripherals connected via cable that work.
with wifi, m16v2 worked immediately...
after download ymal file, re power on of your M16v2 board if you use ethernet.
or do you means can't compile with ethernet version yaml file?
yes, done differently test and reboot, both of the card and of home assistant.
the file is compiled and loaded correctly for the wired network. I used the one posted
