12-17-2023, 12:24 PM
Hi Kincony
There is a breaking change in ESPHOME in 2023.12.0b2 that causes the A8 etc yaml to fail the configuration test.
https://github.com/esphome/esphome/pull/5666
I dont have a test system, not sure if you need to add allow_other_uses: true to each pin or a global entry at the top.
If you could advise that would be good
Thankyou..Peter allow_other_uses: true
