12-17-2023, 06:02 PM
Please tell me an example of the code for working with the GSM module in ESPhome (homeassistant)
KC868-A16S configure yaml for ESPhome
12-18-2023, 12:30 AM
ESPHome not support 4G SIM7600 moudle directly, it only support SIM800L 2G module. here is details:
https://esphome.io/components/sim800l.html
01-15-2024, 05:29 PM
Hi All,
Is there a way to use the analog inputs to control the relays, without a software solution behind? It is working fine with Home Assistant, but for example a centralized light control it would be essential to fallback electronics only if a network outage occurs or sever is unavailable. Thanks!
01-15-2024, 10:47 PM
you can download KCS firmware, make IFTTT command , let analog value to control relay output. here is KCS online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
then you can integrate A16S board to home assistant by MQTT, so that KCS and home assistant can work at the same time.
Online Store: https://shop.kincony.com Alibaba Store: https://kincony.en.alibaba.com/ (01-15-2024, 10:47 PM)admin Wrote: you can download KCS firmware, make IFTTT command , let analog value to control relay output. here is KCS online guide: https://www.kincony.com/esp32-kcsv2-firmware.html Thank you very much, I will check it. Or maybe code it in ESPHome like this: Do you have any consideration? binary_sensor: - platform: gpio name: "a16s-input1" pin: pcf8574: pcf8574_hub_in_1 number: 0 mode: INPUT inverted: true on_press: - switch.toggle: relay01 switch: - platform: gpio name: "a16s-output1" pin: pcf8574: pcf8574_hub_out_1 number: 0 mode: OUTPUT inverted: true id: relay01 Need to add for every channel, with a counter unique relay ID.
01-17-2024, 12:10 AM
yes, i suggest you only use ESPHome is enough, not need to use KCS.
06-10-2024, 01:25 PM
Can the Digital inputs be used for things other than just binary sensors?
06-10-2024, 10:32 PM
what function you want to use? mainly use for binary sensor type.
09-04-2024, 09:39 AM
Hi, everytime I try to upload ESPHOME in the A16S board it shows an error while connecting through serial port. I've attached the screenshot here. Please advise.
Also if I try to connect through LAN connections it requires OTA password. Could you please provide that too.?
09-04-2024, 10:31 AM
take a photo, how you connected with USB-C cable.
