Errno 113
Can't connect to ESPHome API for kc868-a16s @ 192.168.30.85: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.30.85', port=6053))]: [Errno 113] Connect call failed ('192.168.30.85', 6053) (SocketAPIError)
12:04:08 – (ПРЕДУПРЕЖДЕНИЕ) runner.py
kc868-a16s @ 192.168.30.85: Connection error occurred: Ping response not received after 90.0 seconds
12:04:07 – (ПРЕДУПРЕЖДЕНИЕ) runner.py
Almost every day I get this error. After it the device stops responding and I reboot it and then everything works
platform: ESP32
encryption:
key: "iJcfgpwJwZg9ObKzoD9XIa1KAQx8yAy7BZwuo3ye5cg="
ota:
password: "f705fcd4ef788f830ac190213002873b"
sda: 4
scl: 5
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
use_address: 192.168.30.85
# Optional manual IP
manual_ip:
static_ip: 192.168.30.85
gateway: 192.168.30.1
subnet: 255.255.255.0
address: 0x24
address: 0x25
address: 0x22
address: 0x23
# Individual outputs
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
here is config yaml for A16S: https://www.kincony.com/forum/showthread.php?tid=2789
(01-06-2024, 12:16 PM)admin Wrote: here is config yaml for A16S: https://www.kincony.com/forum/showthread.php?tid=2789
didn't help, I'm using this code. how do I use mqtt
do you have such firmware for the a16s
if you want use MQTT integrate to home assistant. just download KCS firmware to A16S, enable "MQTT" protocol.
here is online guide how to use KCS firmware: https://www.kincony.com/esp32-kcsv2-firmware.html
yes, this program is better, but I have three ds18b20 temperature sensors, I know that it will not be possible to connect them to one wire
no, KCS firmware can't use multi sensor with one GPIO.
if you config by ESPHome, then you can use multi sensor with one GPIO, and make MQTT work for your own server.
