60m2 Smart apartment automation project
Hello Kincony,
I've been fallowing you your Youtube page for quite some time.
I've started my home renovation and decided to use your products.
I am quite new to home automation but want to expand my knowladge with DIY project.
The project is for 32 smart relay.
Loads i want to operate with your controllers are  16А x10 ,  10А x 16 ,  20А x6
Sensors i will need for my project is ~  24:   Temperature x6,  Humidity x5,  Air quality x4, Door Sensors  x4,   Motions sensor x5.
I can provide you with my loads chart if needed.
  1. Platform will be based on Home assistant.
  2. Based on your youtube tutuorial the descision was made for:
  3. Controll type: Home Assistant
  4. Main controller:Kingcony KC868-SERVER
  5. Slave controller:Kingcony KC868-A16
  6. Relay extender 1:Kingcony KC868-E16
  7. Relay extender 2:Kingcony KC868-E8
  8. DC contact : x8 Can you please tell me which one, becase there are 2 types in both of Aliexpress and Alibaba store?
  9. Sensor board:Kingcony  KC868-AI
Kindly asking for your assistance if if my pickup choice is correct.
Wiring diagram for this setup will be appreciated.
This setup is already in my Alixpress cart and ready for purchase, so if it needs correction now would be the perfect time.
Many thanks in advance.
Kind regards,
Martin
KC868-E16 v2 is new version, old version is stop produce now.
if you want connect DC contact with KC868-A16 or KC868-Server's output terminal.
you can see this link: https://www.aliexpress.com/item/3256802953791857.html
all diagram at here: https://www.kincony.com/forum/forumdisplay.php?fid=33
(04-17-2024, 06:33 AM)beemasport Wrote: Hello Kingcony,
I've started my home renovation and decided to use home automation service Miami products.
Kind regards,
Martin
Hi Kingcony, I'm new here.
Can you pleas help me? I'm also stuck in the same situation.
I've started and moved the project.
The box is 95% complete.
32 chanels in total.
16+8 omron relay boards + 8 DC contacotrs.
14 relays will control lights in the apartment;
2 will control the exhaust valves for ease of ventiolation;
8 relay will control lower consumption appliances ( according to manual up to 16A) the 8 DC contacors will control higher consumption appliances ( according to manual up to 20A) .
  1. Main controller:Kingcony KC868-SERVER
  2. Slave controller:Kingcony KC868-A16
  3. Relay extender 1:Kingcony KC868-E16 v2
    Note: This board is very convenent the NC ports allows for ventilation valves to stay closed all the time, when the relay is on valves will open with exhaust fans)This might have more uses but as a brand new DIY-er i did not find more uses.
  4. Relay extender 2:Kingcony KC868-E8
  5. DC contact : x8
    Each individual controlled line has a separate live wire.(When having conversation with proffesional electricians, i got the answer that nobody does that because its a waste of wire)
    Size of the box is 80x60cm.
Image of the project so far.
[Image: hPPqmj9]
