05-14-2024, 02:31 PM
Where can I get yaml configuration file for esphome for the diagram attached
Kc868-AM and sensors
05-14-2024, 10:33 PM
what function you want to use?
if want use DS18B20, see here: https://esphome.io/components/sensor/dallas.html
05-15-2024, 06:04 AM
I want to use DS18B20 to control air conditioners, to be turned On and Off based on defined temperature and motion sensor (person Presence)
05-15-2024, 07:31 AM
This is my esphome yaml config file
esphome: name: kc868-am01 friendly_name: Kc868-am01 esp32: board: esp32dev framework: type: arduino # Enable logging logger: # Enable Home Assistant API api: encryption: key: "mWaHqnW3P/nXU0DCEzl3GkixqPp44sawqt6lMh1JiuY=" ota: password: "4512ad14c7069c6f8f0bc1115de315b2" wifi: ssid: !secret wifi_ssid password: !secret wifi_password # Enable fallback hotspot (captive portal) in case wifi connection fails ap: ssid: "Kc868-Am01 Fallback Hotspot" password: "liRZ0Eh243MY" captive_portal: dallas: - pin: 4 id: hub4 - pin: 3 id: hub3 - pin: 2 id: hub2 # Individual sensors sensor: - platform: dht pin: 1 temperature: name: "Master Bedroom Temperature" humidity: name: "Master Bedroom Humidity" model: DHT22 update_interval: 60s The log file shows it is not detecting the sensors. The sensors are connected according to the pins described in the config
05-15-2024, 11:29 AM
take a photo of your board, what have connected, which sensor want to use. question should have details, so that can help you.
Users browsing this thread: |
1 Guest(s) |
