06-17-2024, 04:47 PM
I'm building a new smart home and is prospecting to use KinCony products for the smart controls that will offer me the following features:
- Smart control of devices via ethernet, website, mobile app, wifi and bluetooth, Alexa and home assistance on remote base. Though, I will also use cable for reliability and efficiency.
QUESTIONS:
- Can i integrate smart touch wall switches as a second level control and alternative switch for designated gadget like ceiling led lighting point for manual control?
- In case of KC868 server goes down or hanged. Can kincony manual switch work effectively.
- Can i assign IP address to the kincony server from my home router network without using the sim card, so that it can access internet from my home internet router.
- Can i integrate my water pump level switch to the controller to control the pumping for water to the reservoir.
- Can i integrate a physical timer switch to control designated output for designated gadget or do you have a software that can take care of the timing of some output/terminal from the server.
BUILDING:
- Five Bedroom duplex with two sitting room, one kitchen and control room in Nigeria.
- 80 bulbs. some paired together. I will also use smart touch wall switches to manually switch off/on the lights as a second level control.
- 2 doors sensors with remote access to lock and unlock.
- Temperature sensors and smoke dictators
- What component will satisfy all the requirements in building the kincony smart distribution box?
- 15kw Solar energy powered
I await for your feedback and look forward to work with you and also publish my work on your youtube and other social media channels
Many Thanks.
QUESTIONS:
BUILDING:
Many Thanks.
