07-15-2024, 12:45 PM
you need to send command to sensor to enable i2c. sorry, i am not used it before. mabye you can contact with sensor's seller.
EZO sensor not working
07-15-2024, 01:45 PM
OK let me try testing all of this on a separate ESP32 board. Will share results.
07-16-2024, 11:36 AM
good luck.
07-18-2024, 07:27 AM
(07-16-2024, 11:36 AM)admin Wrote: good luck. Thanks Admin. So I made good progress! Anybody using Atlas Scientific probes: While it works with both UART and I2C, by default the probe is set on UART. To switch the board to I2C, follow these steps: Interfacing Atlas Scientific Ph Sensor with Arduino via UART/I2C (how2electronics.com) UART: led is green, with I2C activated, it's blue. Once done, you will see your probe in the logs. Admin: How do I connect 2 probes (I have a pH and ORP) ? First one is connected using the I2C extender and this works fine. Second one: I tried using the I2C connector on top of the E16P board but it doesn't work.
07-18-2024, 12:00 PM
First one is connected using the I2C extender and this works fine. use by which board? which port? can you upload a photo?
Users browsing this thread: |
2 Guest(s) |
