DHT22 with A32PRO
I am trying to connect DHT22 to A32PRO. I connected three DHT22 pins in the following way:
data pin -> W1
VCC -> 3V3
GND -> GND
There is 10kOm pull up resistor between 3V3 and W1 installed.
This is how I configure DHT22 in ESPHOME:
  - platform: dht
    pin: GPIO1
    model: DHT22
    temperature:
    humidity:
    update_interval: 10s
The status in Home Assistant is "unknown".
What am I doing wrong? Did I connected and configured correctly?
[Image: t-mq0YTWcdl6]
Thank you for explanation in advance.
please upload your photo , how you wire. i can't see your photo.
(08-28-2024, 10:29 PM)admin Wrote: please upload your photo , how you wire. i can't see your photo.
do you have added the extend 10k resistance by yourself? if YES, remove it, our pcb already have the pull-up resistance for 1-wire pin.
(08-29-2024, 08:50 AM)admin Wrote: do you have added the extend 10k resistance by yourself?  if YES, remove it, our pcb already have the pull-up resistance for 1-wire pin.
You are right. It works fine without additional resistor. Thank you fo your help.
you are welcome.
