Loxone Project Templates for KinCony Smart Controller
.zip   Loxone-Project-Templates-KinCony-Controller.zip (Size: 20.2 KB / Downloads: 327)
.zip   KinCony-A8S.zip (Size: 29.09 KB / Downloads: 286)
I’m thinking about using a loxone miniserver to combine Kincony and Loxone all managed by loxone. I have 4 KC868-A16 which i want to combine in a small network (VLAN)with the Loxone server
It is clear to me what the input read and relay set command are, but the “state update” of the relays I don’t really know how to register in Loxone. It has a 8 bits value as a decimal.(as I can read in the documentation)
When you enable a relay it always responds with the state of all relays. How do we integrate that 255,0-255,0-255 value?
Kind regards,
Yes, now the protocol is feedback all relay state. we are designing new relay board will support Loxone by UDP, feedback relay state by single channel, that will be easier. Now the KC868-A16 ESP32 memory almost used fully.
(09-05-2024, 11:39 PM)admin Wrote: Yes, now the protocol is feedback all relay state. we are designing new relay board will support Loxone by UDP, feedback relay state by single channel, that will be easier. Now the KC868-A16 ESP32 memory almost used fully.
Do you know when will the new board be available for bigger Loxone compatibility ?
yes, hardware will finish soon, new model : KinCony B16M.
