KC868-A32 DS18B20 temperature sensor
I want to install DS18B20 sensor and use it instead of analog temperature sensor which is not accurate.
Will be using one of the gpio on the white serial port.
As kcs firmware does not support A32 with DS18B20 sensor, how to make it work.
I can write arudino code to get the temperature if needed, but how can it be use together with kcs firmware?
Need some help. Thank you.
do you use for home assistant?
current set up no, but can set up home assistant if needed
i suggest use our SHT32 sensor, it's better than DHT sensor. high-precision temperature and humidity sensor.
it can conenct to KC868-A32 pcb i2c bus extender directly.
here is video tour: https://youtu.be/frz-AvJpjg4
(09-10-2024, 06:58 AM)admin Wrote: i suggest use our SHT32 sensor, it's better than DHT sensor. high-precision temperature and humidity sensor.
Hi, can SHT32 be supported by KCS firmware? Will KCS firmware support this in the future?
now not supported, if you config by ESPHome, that will be support.
(09-11-2024, 09:50 AM)admin Wrote: now not supported, if you config by ESPHome, that will be support.
It would be nice if the KCS firmware was opensource so it would be easier to contribute and implement further I2C devices and functionality.
For example I'm trying to get EMC2301 / EMC2101 I2C to be controlled by the Kincony board.
do you want only monitor sensor in local network? Not need to use Tuya app for remote monitor?
Any news on connecting DS18B20 to  KC868-A32M?
Thank you, going to use ESPHOME, could I use an ADC PIN and assign it for One-Wire ?
