F16 ESPHome yaml for home assistant
  friendly_name: f16
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
  board: esp32-s3-devkitc-1
    type: arduino
external_components:
  - source:
      type: git
      ref: v1.1.0
  encryption:
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  interrupt_pin: GPIO2
  reset_pin: GPIO1
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
  - id: 'pcf8574_hub_out_1'  # for output channel 1-16
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_in_1'  # for input channel 1-16
    i2c_id: bus_a
    address: 0x24
    pcf8575: true
uart:
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 16
    rx_pin: 17
  - id: tuya_mcu_uart
    tx_pin: GPIO39
    rx_pin: GPIO38
    baud_rate: 9600
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: chmzlgjpadpqxdko
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
  - platform: uart
    uart_id: uart_1
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
  - platform: tuya_wifi_mcu
    dp_id: 1
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "f16_output01"
      mode: OUTPUT
    dp_id: 2
    internal: true
    bind_switch_id: "f16_output02"
      mode: OUTPUT
    dp_id: 3
    internal: true
    bind_switch_id: "f16_output03"
      mode: OUTPUT
    dp_id: 4
    internal: true
    bind_switch_id: "f16_output04"
      number: 4
      mode: OUTPUT
    dp_id: 5
    internal: true
    bind_switch_id: "f16_output05"
      number: 5
      mode: OUTPUT
    dp_id: 6
    internal: true
    bind_switch_id: "f16_output06"
      number: 6
      mode: OUTPUT
    dp_id: 101
    internal: true
    bind_switch_id: "f16_output07"
      number: 7
      mode: OUTPUT
    dp_id: 102
    internal: true
    bind_switch_id: "f16_output08"
      number: 8
      mode: OUTPUT
    dp_id: 103
    internal: true
    bind_switch_id: "f16_output09"
      number: 9
      mode: OUTPUT
    dp_id: 104
    internal: true
    bind_switch_id: "f16_output10"
      number: 10
      mode: OUTPUT
    dp_id: 105
    internal: true
    bind_switch_id: "f16_output11"
      number: 11
      mode: OUTPUT
    dp_id: 106
    internal: true
    bind_switch_id: "f16_output12"
      number: 12
      mode: OUTPUT
    dp_id: 107
    internal: true
    bind_switch_id: "f16_output13"
      number: 13
      mode: OUTPUT
    dp_id: 108
    internal: true
    bind_switch_id: "f16_output14"
      number: 14
      mode: OUTPUT
    dp_id: 109
    internal: true
    bind_switch_id: "f16_output15"
      number: 15
      mode: OUTPUT
    dp_id: 110
    internal: true
    bind_switch_id: "f16_output16"
      pcf8574: pcf8574_hub_in_1
    dp_id: 111
    bind_binary_sensor_id: f16_input01
    internal: true
    dp_id: 112
    bind_binary_sensor_id: f16_input02
    internal: true
    dp_id: 113
    bind_binary_sensor_id: f16_input03
    internal: true
    dp_id: 114
    bind_binary_sensor_id: f16_input04
    internal: true
      number: 4
    dp_id: 115
    bind_binary_sensor_id: f16_input05
    internal: true
      number: 5
    dp_id: 116
    bind_binary_sensor_id: f16_input06
    internal: true
      number: 6
    dp_id: 117
    bind_binary_sensor_id: f16_input07
    internal: true
      number: 7
    dp_id: 118
    bind_binary_sensor_id: f16_input08
    internal: true
      number: 8
    dp_id: 119
    bind_binary_sensor_id: f16_input09
    internal: true
      number: 9
    dp_id: 120
    bind_binary_sensor_id: f16_input10
    internal: true
      number: 10
    dp_id: 121
    bind_binary_sensor_id: f16_input11
    internal: true
      number: 11
    dp_id: 122
    bind_binary_sensor_id: f16_input12
    internal: true
      number: 12
    dp_id: 123
    bind_binary_sensor_id: f16_input13
    internal: true
      number: 13
    dp_id: 124
    bind_binary_sensor_id: f16_input14
    internal: true
      number: 14
    dp_id: 125
    bind_binary_sensor_id: f16_input15
    internal: true
      number: 15
    dp_id: 126
    bind_binary_sensor_id: f16_input16
    internal: true
##pull-up resistance on PCB
      number: 48
      number: 47
      number: 21
      number: 15
## without resistance on PCB
      number: 13
      inverted: false
      number: 14
      inverted:  false
      number: 40
      inverted:  false
  - platform: adc
    pin: 5
    name: "F16 A1 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
          } else if (x <= 0.15) {
            return 0;
          } else {
            return x * 1.51;
  - platform: adc
    pin: 7
    name: "F16 A2 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      # - multiply: 1.51515
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
            return 0;
          } else {
            return x * 1.51;
  - platform: adc
    pin: 6
    name: "F16 A3 Current"
    update_interval: 5s
    unit_of_measurement: mA
    attenuation: 11db
    filters:
      - multiply: 6.66666666
  - platform: adc
    pin: 4
    name: "F16 A4 Current"
    update_interval: 5s
    attenuation: 11db
    filters:
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "KinCony F16");
download yaml file:
.txt   F16-HA.txt (Size: 14.19 KB / Downloads: 91)
good day sir,
       when will you release the kcs software for F16?
       Does the kcs software for F16 support auto detection in Home Assistant?
i will wait for the kcs software =)
Yes, we are waiting for the KCS software. Can we use the free GPIOs with the new KCS software update?
(10-15-2024, 02:08 AM)NewONE Wrote: good day sir,
Yes, we are designing KCS v3 firmware for ALL new "ESP32-S3" controllers, will release in furture. KCS v3 will support auto detection in Home Assistant function.
(10-15-2024, 06:17 AM)engrezk Wrote: Yes, we are waiting for the KCS software. Can we use the free GPIOs with the new KCS software update?
Can you take an example, how do you use free GPIOs in KCS firmware.
Can they be used for learning IR transmission and reception, for example?
F16 board not have IR sender and receiver.
