Threads: 930
Do you think if KC868-AP remove the PCA9685 , use ESP32 pins connect to driver IC directly will be ok?
how many channel you want? maybe ESP32-S3 not have enough GPIOs for PWM output.
Threads: 930
which MOSFET driver IC model you think is ok?
Threads: 0
Just wanted to put in my support for a direct driven mosfet product offering, even with less outputs. (Not going through a expander IC) Having more control over the PWM frequency is very much needed for a lot of applications.
Threads: 930
because B16M mosfet contrl by PCF8575, not by ESP32-S3's pin directly.
