DS18B20 longer distance
Hello I have 10x DS18B20 temp sensors hooked up to KC868-AIO
They are mostly around 50-70ft away from the KC868-AIO
They are all home run cable back to KC868-AIO (star patern)
The cable used is 18/3 OFC copper.
I can only get them to work if hooked directly up short run without extending them.
How can I get this setup to work? Resistors? If so what kind?
Thanks
You can use thick shielded wire for testing.
here is video tour about long cable for DS18B20: https://youtu.be/4DfJnC3Wd2k
(11 hours ago)admin Wrote: You can use thick shielded wire for testing.
I cannot re run any wire. We have 18 gauge 3 conductor already ran inside walls.
Can a resistor be added or what other options?
maybe you can use KC868-AM + DS18B20 place to any place independently. all these can integrate to home assistant.
(9 hours ago)admin Wrote: maybe you can use KC868-AM + DS18B20 place to any place independently. all these can integrate to home assistant.
In your video. Is that 14awg wire? it says 2.5??
Would I be able to have multiple runs of that in star pattern?
We need 10 temp sensors.
How would I fit them all into the boards little connector?
Would I splice them all together into 3 wires at the end?
Can resistors be uses at all? Or no because there is one built into the board already?
silicondt, 1 Guest(s)
