12-27-2024, 09:33 AM
Hey,
first of all: Thanks for this great product! I am now trying to connect it via MQTT to Home Assistant. (I had several issues by using ESPHome, so I wanna stick with MQTT for now).
What I did:
I have used the following YAML within Home Assistants configuration.yaml, customized based on the received packages while listening to #:
As a result, I can - after restarting Home Assistant control the Output 1.
BUT: It does not show the current status of Output one! (See Screenshot). Status is unknown.
Any Idea what went wrong? What could I check?
What I did:
- MQTT Setup within KCS
- Setup Mosquito and MQTT within Home-Assistant (Already existing)
- Confirmed that the Packages are received by listening to #
mqtt:
- name: 'kcs868-a16-output-1'
unique_id: kcs868-a16-output-1
state_topic: 'KC868_A16/2CBCBB646ACC/STATE'
command_topic: 'KC868_A16/2CBCBB646ACC/SET'
payload_on: '{"output1":{"value":true}}'
payload_off: '{"output1":{"value":false}}'
state_on: true
state_off: false
