KinCony ESP32-S3 Core Board released
We have designed ESP32-S3 Core Board - KinCony S3. it's mini PCB, support install by DIN RAIL. it use ESP32-S3-WROOM-1U N16R8 chip. small PCB with RS485, I2C bus, 1-wire, analog input ports. analog input port can use for VOLTAGE / CURRENT signal set by jumper. It have ethernet port, also have SIM7600 4G module and RF 433MHz reciever interface. It can use for smart home IoT project use by home assistant, you can config ymal by ESPHome. S3 also support arduino IDE / MicroPython / ESP-IDF development tool.
[Image: S3-1.jpg]
PCB size: 80mm*65mm
Power supply: DC 9-24V
[Image: S3-schematic.jpg]
I just purchased this product but I am having difficulty figuring out how to flash the program. I would appreciated it if you inform me.
1. if you want to use by home assistant, you can config by ESPHome.
2. if you want to write your own code, such as arduino IDE, you can write code and download to ESP32-S3 chip by USB-C cable.
(10-04-2024, 12:35 AM)admin Wrote: 1. if you want to use by home assistant, you can config by ESPHome.
i am using arduino ide for programming, however i having a problem when it is difficult to load the firmware.How to setup correct board ?
i am using arduino ide for programming, however i am having problem when it is difficult to load the firmware. How to setup so I can load the code using USB type c on the board
chose this board.
(10-03-2024, 02:43 PM)tugrul Wrote: I just purchased this product but I am having difficulty figuring out how to flash the program. I would appreciated it if you inform me.
Good day I have the same problem did you get a solution as to how to get the firmware loaded if so could you please share a link if possible to the correct firmware please.
if you want download KCS firmware , here is online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
or do you MUST want write your own arduino code to ESP32?
