HA + Loxone + NSPanel
Hi all,
Do you have solutions for HomeAssistant which is cooperating with Loxone over NSPanels?
I mean I am looking for controllers with power output as NSPanel will use virtual inputs on Loxone and Loxone will execute commands over mqtt/http on your controllers
Any idea? Examples? Controllers without Input?
Best Regards
Krzysztof
NSPanels can modify UI to control other device? it have relay inside, i think ONLY the UI control inside relay.
Not sure what you're trying to do, but here is what I have in place:
- each room has an NSPanel Pro in the wall, that replaced the traditionnal wall switches. On the NSPanel Pro, I removed the UI from NSPanel to access android, and I installed the Home Assistant client and Fully Kiosk (Fully Kiosk enables a few nice features such as remote screen activation, automatic startup of HA at boot etc.)
- in Home Assistant I designed a different dashboard for each NSPanel, with the different room controls - lights, heating, curtains, window covers, Sonos etc.
- most of these controls are operated through Kincony H32B Pro boards - most lights, the covers, the heating are all activated by relays on the Kincony board
From what I know about Loxone, you should be able to do the same with it instead of Home Assistant - I'm just not sure you can have a client for the NSPanel pro that drives Loxone systems.
You should also use extra, more powerful relays for most lights and high-current loads as explained here https://shop.loxone.com/enen/product/200...y?___SID=U
if you using A32 Pro, F16, F24, B16M controller, download KCS firmware, they can integrate to Loxone miniserver directly by UDP command. we have video tour about that: https://www.kincony.com/forum/showthread.php?tid=7264
