A24 Where DAC?
Good day, admin, please tell me, do you have a video https://www.youtube.com/watch?v=kLUGJtZg1aQ, the description says the following "how to slove A32 Pro/A24 DAC dimmer"
However, I do not see the inscription on the case as for the A32 PRO DA1 and DA2 in the lower right corner of the case is located on the A32 Pro
So does the KinCony A24 https://aliexpress.ru/item/1005006364867...757axPMWYQ
have dimmer control? If so, where are the inscriptions?
Thanks
[Image: A24-1_07.jpg]
on the right top GREEN terminal (beside RS485 port) , there are V0, V1 means 2 channel of DAC output (DC 0-10V)
Thank you, there is just no diagram here https://www.kincony.com/forum/forumdisplay.php?fid=33
And the interface is already called differently, so only questions arise, thanks again, you are the best.
Help please, how many temperature sensors can be connected to the 1wire interface of the A24 board???
5 - 10 or 10 - 20? What is the maximum number you tested?
one GPIO port only use for one sensor.
You previously showed https://www.youtube.com/watch?v=M8wL69S5YBQ how to connect 10 ds18b20 temperature sensors to the a4 board.
Do I understand correctly that this method will not work in A24??
if you config by ESPHome, it's ok work with multi sensors.
my means KCS firmware only support one GPIO for one sensor.
