07-01-2024, 12:00 PM
great post
KC868-H32B V5.08 firmware
great post
08-27-2024, 07:19 PM
Hi Admin,
Does the firmware upgrade reset the config to factory default or the configuration is preserved during FW upgrade? Thanks.
08-27-2024, 09:59 PM
after download firmware, the config will be clear. Need to set again.
02-10-2025, 12:56 PM
I'm completely new to this.
I recently purchased an H32B Pro relay controller and need to integrate it with a Raspberry Pi 5 and Home Assistant. My goal is to use the relays to control the lighting system of my small vertical farm on a timer. I bought the H32B a month ago, but unfortunately, it came with an outdated firmware version: H32B_Pro_V1.19. I was expecting it to be updated before shipping, so this is quite disappointing. From what I’ve read here, it looks like I need firmware version 4 for proper integration. The issue is that I only have Apple Macs in my office, and my only connection options are LAN via the modem or Wi-Fi. I have no idea how to update the firmware, which version to download, or how to install it. Any guidance would be greatly appreciated! Thanks in advance.
02-10-2025, 12:59 PM
H32B_Pro_V1.19 already is newest firmware.
you are looking at H32B, NOT H32B Pro. so your firmware can work with interlock mode is OK, you want "interlock" option with your motor. |
Users browsing this thread: |
1 Guest(s) |
