KinCony controller to Mushroom farm
Hi everyone,
I'm new to this forum and new to ESP/Home Assistant.
I have a mushroom cultivation tent where I use a humidifier, blower motors, LED lights, sensors, and an electric heater.
Currently, I control the climate using WiFi-connected sensors, but I would like to fully automate all devices and manage them using Home Assistant (I already have a server and WiFi infrastructure set up).
I'm unsure which Kincony controller would be the best choice, so I’d appreciate your advice. I've attached a diagram showing the devices I want to connect to the controller.
List of devices and required functions in Home Assistant:
  • Electric Heater (PTC 1.5 kW): Turn on/off based on the temperature sensor.
  • Humidity, Temperature, and CO2 Sensor: Read and monitor sensor data.
  • UV Lamp (in humidifier water container): Activate for short intervals (e.g., every 10 seconds).
  • Blower Motor: Adjust fan speed based on CO2 sensor readings.
  • LED Lights: Run for 12 hours daily with adjustable intensity.
  • Humidifier: Turn on/off based on the humidity sensor.
Thanks in advance for your help!
Krzysztof
i suggest you chose kincony F16 controller, here is details: https://www.kincony.com/esp32-s3-tuya-re...d-16a.html
you can connect to your loads directly.it use by high quality 16A removable relay. the temperature humidity sensor chose KinCony TS. CO2 sensor use by 4-20mA or 0-5v signal type.
(02-22-2025, 12:46 AM)admin Wrote: i suggest you chose kincony F16 controller, here is details: https://www.kincony.com/esp32-s3-tuya-re...d-16a.html
Thank you for your help! I bought the F16 controller. I will test my project, and I hope to share my results with you soon.
thanks.
