02-21-2025, 11:30 PM
Hi everyone,
I'm new to this forum and new to ESP/Home Assistant.
I have a mushroom cultivation tent where I use a humidifier, blower motors, LED lights, sensors, and an electric heater.
Currently, I control the climate using WiFi-connected sensors, but I would like to fully automate all devices and manage them using Home Assistant (I already have a server and WiFi infrastructure set up).
I'm unsure which Kincony controller would be the best choice, so I’d appreciate your advice. I've attached a diagram showing the devices I want to connect to the controller.
List of devices and required functions in Home Assistant:
Thanks in advance for your help!
Krzysztof
- Electric Heater (PTC 1.5 kW): Turn on/off based on the temperature sensor.
- Humidity, Temperature, and CO2 Sensor: Read and monitor sensor data.
- UV Lamp (in humidifier water container): Activate for short intervals (e.g., every 10 seconds).
- Blower Motor: Adjust fan speed based on CO2 sensor readings.
- LED Lights: Run for 12 hours daily with adjustable intensity.
- Humidifier: Turn on/off based on the humidity sensor.
Krzysztof
