03-01-2025, 10:44 AM
Hello!
I hope you will be fine. I bought 4 KC868-A16 for trial purpose for my company. If suitable we will buy more But I am not able to program it until now. So I was thinking Kindly Can I get your WhatsApp so that any of your technical support Staff can guide me how to program KC868-A16 with Arduino IDE software.
I had connected the power and ethernet port with my laptop for programming. Also I had selected the board as Nodemcu32s and selected the right port. When I start uploading the your demo code, I don't why the program doesn't upload and give me the following error;
"Sketch uses 316512 bytes (24%) of program storage space. Maximum is 1310720 bytes.
Global variables use 21008 bytes (6%) of dynamic memory, leaving 306672 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.8.1
Serial port COM5
A serial exception error occurred: Cannot configure port, something went wrong. Original message: PermissionError(13, 'A device attached to the system is not functioning.', None, 31)
Note: This error originates from pySerial. It is likely not a problem with esptool, but with the hardware connection or drivers.
For troubleshooting steps visit: https://docs.espressif.com/projects/espt...oting.html
Failed uploading: uploading error: exit status 1"
Could you identify what I am doing.ad connected the power and ethernet port with my laptop for programming. Also I had selected the board as Nodemcu32s and selected the right port but I don't why the program doesn'
I will appreciate your help in this regard.
Thankyou,
Muhammad Azhar Uddin
Lead Engineer
Taqueen Innovation Company, KSA
+966582841063
esptool.py v4.8.1
Serial port COM5
Thankyou,
Lead Engineer
+966582841063
