Etgernet + wifi
#31
just re download KCS firmware to ESP32.
(03-24-2025, 11:29 AM)kulibin Wrote:
(02-06-2025, 10:54 AM)kulibin Wrote:
(02-06-2025, 08:45 AM)admin Wrote: if use KCS firmware, let board integrate to home assistant by MQTT, not by ESPHome.
If I install KCS firmware and I don't like it, can I go back?
How i can return from KCS firmware to factory settings ? For used in ESP Home Assistants ?
Now I have KCS firmware. I want to go back to factory firmware to work with ESP Home. The firmware with which I bought
if you want use by ESPHome, just download ESPHome firmware to ESP32, just overwrite it.
(03-25-2025, 10:16 PM)admin Wrote: if you want use by ESPHome, just download ESPHome firmware to ESP32, just overwrite it.
Unable to install the ESP32 firmware. If I install the standard version of the ESP32 with WiFi, then everything works, and if I install your code with ethernet, then an error is constantly
Successfully created esp32 image.
esp32_create_combined_bin([".pioenvs/cotelna/firmware.bin"], [".pioenvs/cotelna/firmware.elf"])
Wrote 0xaa410 bytes to file /data/build/cotelna/.pioenvs/cotelna/firmware-factory.bin, ready to flash to offset 0x0
========================= [SUCCESS] Took 84.96 seconds =========================
INFO Successfully compiled program.
esptool.py v4.7.0
Serial port /dev/ttyUSB0
Connecting................
ERROR Running command failed: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
ERROR Please try running esptool.py --before default_reset --after hard_reset --baud 460800 --port /dev/ttyUSB0 --chip esp32 write_flash -z --flash_size detect 0x10000 /data/build/cotelna/.pioenvs/cotelna/firmware.bin 0x1000 /data/build/cotelna/.pioenvs/cotelna/bootloader.bin 0x8000 /data/build/cotelna/.pioenvs/cotelna/partitions.bin 0xe000 /data/cache/platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin locally.
INFO Upload with baud rate 460800 failed. Trying again with baud rate 115200.
esptool.py v4.7.0
Connecting...
ERROR Please try running esptool.py --before default_reset --after hard_reset --baud 115200 --port /dev/ttyUSB0 --chip esp32 write_flash -z --flash_size detect 0x10000 /data/build/cotelna/.pioenvs/cotelna/firmware.bin 0x1000 /data/build/cotelna/.pioenvs/cotelna/bootloader.bin 0x8000 /data/build/cotelna/.pioenvs/cotelna/partitions.bin 0xe000 /data/cache/platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin locally.
which board model you are using?
