The response to clicks does not work correctly
Hello, I configured the kincony A8 v1.6 as follows. I have the latest firmware available for this model at the moment v2.2.13.
I am trying to configure the switch so that a single press turns on relay 8, and a long press turns on relays 1 through 4, but I don't like that even if I make a long press, relay 8 turns on, which should only turn on with a short press, and I don't want to constantly turn it off after making unnecessary movements, how can I fix this?
The goal is to turn on relay 8 with a short press, turn on relays 1 through 4 with a long press, and not even turn on relay 8.
A video demonstrating my setup is below.
https://cloud.mail.ru/public/kzD9/foVXqnA1Z
Help me PLZ.
after you config IFTTT. do you have re power on of board? it MUST need reboot.
(05-12-2025, 01:08 AM)admin Wrote: after you config IFTTT. do you have re power on of board? it MUST need reboot.
Yes, I tried rebooting the equipment, but it doesn't help, when holding the key for a long time, relay number 8 still works, I tried working with different IF by enabling the logical AND parameter, but my attempts have been unsuccessful so far.
we will test.
(05-12-2025, 08:40 AM)admin Wrote: we will test.
Good afternoon, please advise the time frame for my question, when will you be able to test it?
we will test after 1 week, because KC868-A8 not in stock now.
if you want use click and hold on at the same time, you should chose "single click" instead of "rising edge". we have tested ,it's ok.
Thanks, I'll really be able to check in 2 weeks.
I have kincony controllers already assembled in the dashboard.
Thank you very much, I love your product.
ok, good.
