IFTT logic
Hi
Is it possible to program such logic to count the time from the signal on DI1 to the signal on DI2, and then on DI3...?
If the time was too short, output channel 1 will turn on, and if too long, output channel 2?
Can you please instruct me?
It should be possible, you just have to think about the problem in ladder logic.  In this case I'm not quite sure what you're asking for, but the general plan is when you get an input on DI1 then set a timer, then AND it with the DI2 input and feed it to the next rule which can use AND or OR to decide what you want.  However doing this requires the ability to feed the output from one rule into the input to another which the software currently doesn't support, although there's a request in another thread to add it.
(05-11-2025, 07:09 PM)twostar Wrote: It should be possible, you just have to think about the problem in ladder logic.  In this case I'm not quite sure what you're asking for, but the general plan is when you get an input on DI1 then set a timer, then AND it with the DI2 input and feed it to the next rule which can use AND or OR to decide what you want.  However doing this requires the ability to feed the output from one rule into the input to another which the software currently doesn't support, although there's a request in another thread to add it.
Exactly as you write, maybe admin can help me, and maybe some timing relays (additional ) would help with this, e.g. https://pl.aliexpress.com/item/100500599...dis!PLN!20 .32!6.10!!!!!%40!12000035395443605!ppc!!!&src=google&albch=shopping&acnt=897-548-8760&isdl=y&slnk=&plac=&mtctp=&albbt=Google_7_shopping&aff_platform=google&aff_short_key=UneMJZVf&gclsrc=aw. ds&&albagn=888888&&ds_e_adid=734597905351&ds_e_matchtype=search&ds_e_device=c&ds_e_network=g&ds_e_product_group_id=2401200754026&ds_e_product_id=pl1005005994998871&ds_e_product_merchant_id=5080937310&ds_e_product_country=PL&ds_e_product_language=pl&ds_e_product_channel=online&ds_e_product_store_id=&ds_url_v=2&albcp=22275934707&albag=175821700255&isSmbAutoCall=false&needSmbHouyi=false&gad_source=1&gad_campaignid=22275934707&gbraid=0AAAAAoukrzhbhFpGcwNvho56GSB- 2pj-o&gclid=CjwKCAjwuIbBBhBvEiwAsNypvW9bzcSW6ZdkVZdtCTHYmrPlYI8CDVt8hw6lv0LVNqZhoK5jxG4-tBoC_uYQAvD_BwE
