Could you help me about rs232 port for your product that desighed RS232 female on board so I want to connect with modbus 485 devices that is ,must convert rs232 to TTL (use max232) nad then use max 485 so I try to connect but can not show the data Rx ,TX .
firstly ,testing the rs232 alone by pin 2 (tx) connect to LED series with resistor 1 k the result was LED blinking and also verified by connecting pin RX and TX together then checking the serial monitor so its can shows the data and then conneecting rs232 with Max 232 after that the result can not show as the last .
