sample code to receive http get
Hello Admin,
Have you ever created an example Arduino program to get results from API calls (HTTP/HTTPS Web Server)?
Btw, I used Kincony F16 ESPS3 with Tuya.
And I have already tested mostly features in the KCS V3 firmware.
Thank you very much.
https://www.kincony.com/forum/showthread.php?tid=2129
and how to get the Device Serial Number from Arduino?
arduino code and KCS firmware can't use at the same time.
Ok, let say i want to use KCS or Arduino. I choose one.
the situation is like this:
My F16 act as a client and want to access a web server on the public IP address (https://nnn.nnn.nnn.nnn/getstatus.php?sn=xxxxx&Relay=1).
That API (getstatus.php....) will get return value (on/off).
the question is:
Can I use KCS to do that? if yes, how to do that?
If KCS cannot do that, then I have to create my own code using arduino. And please give me sample arduino code to do that.
Thank you
the question is:
Thank you
if you can use WAN ip directly, you can write your own arduino code.
if you want create a cloud server, you can download KCS firmware, let F16 connect to your cloud server by MQTT, then you can write your own webpage on cloud server, maybe use java.
(12-28-2025, 01:57 AM)admin Wrote: if you can use WAN ip directly, you can write your own arduino code.
Thank you for the clear explanation. Idea
And i want to confirm such think.
I used cloud server, then i will use KCS firmware.
Based on your recommendation, i will use MQTT protocol.
I tried to configure MQTT F16 like in the picture below.
the next question is:
1. is it correct for this configuration setting?
    Protocol -> General: MQTT enable [on]
    input broker address on the cloud server, and the port.
    i will filled user name & password later.
2. what is the state topic meaning? it look like mac address for the wifi/lan with addition string F16 & STATE
3. what is the command topic meaning? also it same like above. but addition string is SET
here is mqtt protocol document: https://www.kincony.com/forum/showthread.php?tid=7619
(12-28-2025, 10:54 AM)admin Wrote: here is mqtt protocol document: https://www.kincony.com/forum/showthread.php?tid=7619
Awesome....
Now, we can use our own MQTT broker...
Thank you
