Http protocol
If i want to control relay controller by another relay controller with http protocol (for example: controlling B16 by A32 pro ), what i should write in the URL, what i should enable?
I would like if you give full explanation.
you can send tcp or http command to another controller , set by IFTTT.
here is example of video tour: https://youtu.be/UumHtpZiURY
In this video there is no example of using http protocol.
1. Whe in enable http protocol in A32 pro, what i have to put in “request”?
2. Also when i enable http protocol in B16, what i have to put in “request”?
3. In coustom protocol, what i have to set, “http post” or “http get?
4. Then i have to use the “message” or “URL”?
1-2: for example , http command: http://192.168.1.200/ctrl.cgi?secret=abc...=0&value=0
3:use GET
4:in URL
So this http command i have to put in both A32 pro and B16?
In this case, how can i define which relay to control in B16 when i set custom protocol?
if you want A32P to control B16, set IFTTT in A32 Pro. enable B16 HTTP protocol.
create your customize protocol HTTP command, that will decide which relay to turn on/off.
Great, now it’s working.
Question:
In case i want to control 20 B16 controllers by kc-868 ak,is there a possibility to do that?
Because i see limited number of protocols :
1. Http server
2. Tcp server
3.Tcp client
4. Udp server
5. Udp client
6.rs485
7.rs232
8. Mqtt
why not use different protocol, use only HTTP command to control 20pcs of B16 controller, OK?
Great, i got the point.
Now i know to do that.
So using http protocol is just for pcb’s which have kcs v3 right?
yes, 20pcs of B16 all downloaded KCS v3 firmware, enabled HTTP protocol, because of every B16 have different IP address.
