ESP system with BTS7960 IBT_2
Hello, I have an issue, maybe you guys can help me. I have bought a BTS7960 IBT_2 to control a motor (12v Linear actuator). But I have problems with the KC868-A6, not booting up correctly (Does not enable wifi, does not get online on HomeESP in Home Assistant) if I have added the BTS7960 IBT_2 from VCC to 3.3V port. I believe it might be because the BTS7960 IBT_2 need 5V and this puts to much load on the KC868-A6 to boot up correctly? Do you know if this issue, and do you know if my suspicion is correct. (If I connect the VCC to 3.3V after it has booted up and is active on wifi, it works fine with the motor)
From what I understand about the BTS7960 IBT_2, is that it should also with with 3.3V
To clearfy I am using KC868-A6-V1.4SP
Thanks!
can you write a diagram on paper.
I manage to resolve the issue, buy adding a DC12v to DC5v Step-Down converter and connect that in this way:
GND from 5V DC converter to GND on the KC868-A6-V1.4SP.
GND from 5V DC converter to GND on the BTS7960 IBT_2
5V DC from 5V DC converter to VCC on the BTS7960 IBT_2
5V DC from 5V DC converter to R_EN and L_EN on the BTS7960 IBT_2 (To always have motor enabled)
This resolved my boot issue with the KC868-A6-V1.4SP..
(07-04-2026, 05:04 PM)SchmidtGundersen Wrote: Hello, I have an issue, maybe you guys can help me. I have bought a BTS7960 IBT_2 to control a motor (12v Linear actuator). But I have problems with the KC868-A6, not booting up correctly (Does not enable wifi, does not get online on HomeESP in Home Assistant) if I have added the BTS7960 IBT_2 from VCC to 3.3V port. I believe it might be because the BTS7960 IBT_2 need 5V and this puts to much load on the KC868-A6 to boot up correctly? Do you know if this issue, and do you know if my suspicion is correct. (If I connect the VCC to 3.3V after it has booted up and is active on wifi, it works fine with the motor)
Thanks!
Hej  Schmidt,
  • Does the board boots without  BTS7960 IBT_2 connected to the board ?
  • Are you using the firmware or your own code?
Best regards
Zali
Thanks!
Hej  Schmidt,
Hello Zali, I am using my own YAML code. Yes, the board boots normally, without the H-Bridge connected to the board.
But after changing power to 5V it works fine. Smile
