09-06-2026, 05:56 PM
Hello, we recently bought and set up the KC868-A8S with a Midea heat pump. ESPHome was used to set up the switches, binary sensors and modbus. The first two work as intended, while the modbus seemingly not being able to read or send requests properly.
Here is the chunk of the code that relates to and might influence the modbus and one of the sensors:
Attempted fixes (that did not work):
At the moment, with this code, the log output repeats these lines:
We are unsure of what to do, and I am out of ideas on how to fix this.
All the GPIOs are correct. They have been checked.
Any help would be appreciated,
Thank you
friendly_name: Centralina freddo
variant: ESP32
flash_size: 4MB
encryption:
key: [cencored for privacy]
ota:
- platform: esphome
password: [cencored for privacy]
- id: bus_a
sda: GPIO4
scl: GPIO5
type: LAN8720
clk:
pin: GPIO17
mode: CLK_OUT
mdc_pin: GPIO23
mdio_pin: GPIO18
phy_addr: 0
uart:
- id: uart_1
tx_pin: GPIO33
rx_pin: GPIO32
baud_rate: 9600
stop_bits: 1
parity: NONE
data_bits: 8
rx_full_threshold: 8B
debug:
direction: BOTH
modbus:
- id: modbus_1
uart_id: uart_1
role: client
modbus_controller:
- id: modbus_controller_1
address: 0x01
modbus_id: modbus_1
setup_priority: -10
update_interval: 15s
- platform: modbus_controller
name: "Temp. Esterna (PdC)"
modbus_controller_id: modbus_controller_1
address: 107
register_type: holding
unit_of_measurement: °C
device_class: temperature
state_class: measurement
value_type: S_WORD
accuracy_decimals: 1Attempted fixes (that did not work):
- phisically inverting the A and B connections
- changing the modbus controller adress
- changing the sensor adress to hexadecimal
- changing the register type
- changing the value type
- adding accuracy decimals
- changing th esp variant from inf to dev
- changing the api to be more generic
- inverting the tx and rx pins
- changing the parity to even and odd
- changing the amount of data bits
- changing the amount of rx_full_threshold
- removing the client role
- removing the uart id
- changing the update interval
- decreasing the turnaround time to 50ms
Quote:[19:49:26.943][W][modbus:1214]: Clearing buffer of 21 bytes - timeout after partial response 1188899ms after last send
[19:49:26.954][D][uart_debug:113]: <<< 7E:66:66:00:66:F8:FE:18:E6:FE:E6:F8:FE:FE:E6:06:FE:E6:F8:FE:FE
Quote:[19:50:11.845][D][modbus:1118]: Frame already active for 1 with 2 requests pending, refused
[19:50:11.847][D][modbus_controller:204]: Poll refused by hub for range 0x68
Thank you
