11-06-2026, 05:35 AM
* Description:
* This Arduino program reads the state of two 16-channel XL9555SS I/O expanders
* and prints the state of all input pins (1-24) to the Serial Monitor. The state of
* each pin is represented as a bit in a 24-bit value, where each bit corresponds
* to an input pin. The program prints the input state in binary format.
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* - XL9555SS I2C Address: 0x24 for inputs 1-16, 0x26 for inputs 17-24
#include "Arduino.h"
#include <Wire.h>
#include <PCA95x5.h>
// Define I2C pins
#define I2C_SDA 8 // Define SDA pin
#define I2C_SCL 18 // Define SCL pin
constexpr uint8_t INPUT_ADDR_1 = 0x24;
constexpr uint8_t INPUT_ADDR_2 = 0x26;
PCA9555 inputIO1;
PCA9555 inputIO2;
Wire.begin(I2C_SDA, I2C_SCL); // Initialize I2C with defined SDA and SCL pins
// Configure both expanders for the input-only test.
inputIO1.attach(Wire, INPUT_ADDR_1);
inputIO1.polarity(PCA95x5::Polarity::ORIGINAL_ALL);
inputIO1.direction(PCA95x5::Direction::IN_ALL);
// Read only ports 0-7 on 0x26. Leave the relay ports undriven.
inputIO2.attach(Wire, INPUT_ADDR_2);
inputIO2.polarity(PCA95x5::Polarity::ORIGINAL_ALL);
inputIO2.direction(PCA95x5::Direction::IN_ALL);
Serial.println("KinCony F24 24 channel input state 0:ON 1:OFF");
// DI1-16 occupy bits 0-15; DI17-24 occupy bits 16-23.
const uint32_t first = inputIO1.read();
const uint32_t second = inputIO2.read() & 0x00FFU;
const uint32_t state = first | (second << 16);
// Print the state of all 24 inputs in binary format
Serial.print("Input state: ");
Serial.println(state, BIN); // Print the state of inputs in binary
delay(500); // Delay 500ms
2-digital-input-9555.zip (Size: 1 KB / Downloads: 35)
2-digital-input-9555.ino.merged.zip (Size: 194.2 KB / Downloads: 39)
