  • 1 Vote(s) - 5 Average
[Arduino IDE of KC868-E16S]--#00-KC868-E16S-configure for ESPhome
Thumbs Up
  platform: ESP32
  sda: 16
  scl: 15
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
#  manual_ip:
#    static_ip: 192.168.1.199
#    gateway: 192.168.1.1
#    subnet: 255.255.255.0
    address: 0x21
    address: 0x25
    address: 0x22
    address: 0x24
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_2
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      pcf8574: pcf8574_hub_in_1
      number: 4
      number: 5
      number: 6
      number: 7
      pcf8574: pcf8574_hub_in_2
      number: 4
      number: 5
      number: 6
      number: 7
> we designed the KC868-E16S ESP32 home automation extension relay module.
Why "extend a relay module"? Why not a "smart controller" such as KC868-A8 or KC868-A64? For me, KC868-E16S is an "extended" KC868-A16 with a relay module for a DIN rail KC868-E16 Smile. In my opinion, a more logical name is KC868-A16E (KC868-A16 + relay module).
KC868-E16S is a very expandable controller, but the ethernet and USB connectors were badly designed because it is not possible to use a case box, the same is true for the KC868-A64. Why USB-B appeared on the board, who uses such a connector? Wink
Best regards
macek
(05-20-2022, 01:23 PM)macek Wrote: Hello,
Best regards
macek
I program PLCs and USB-B is widely used.  I much prefer the larger USB connector for programming as the USB-C is fragile......its a good choice...
Peter
Because the connecting wire comes out from the side, it will be blocked by the plastic shell.
Can u please give more details to 24v?
I have a full 24V system. Can I use 24v as power supply? As inputs? What kind of boardshould I buy?... on Ali is no choice to select 24v edition
what do want use 16 channel output version?
Can I use 24v on input pins?
If I use 24v is there anything else what I have to consider?
KC868-E16S if replace with DC24V relay, board can use for 24v, so you can use 24v as power supply.
if you want use 24v on input pins for long time, you'd better replace a resistance 2K with 5.6K at input port on PCB.
no other need to consider. just input port resistance.
if you want 24v version, tomorrow our seller will update type on aliexpress store.
Thank you for fast answer.
2 more questions:
Do you know how I can extend input ports?without buying a second board
Is 1 wire temp sensor possible?
if you want to extend input ports, here two ways:
1. add a board connect to network cable with your router.
2. use IIC extender, such as PCF8574 or PCF8575 small board connect to "IIC extend interface " on the PCB board.
if you want to use 1 wire temperature sensor, such as DS18B20 or DHT11/21, you can connect to "serial port extend interface" on the PCB board. there are two free GPIO pins for use, now is use for TXD,RXD, but actually you can use for yourself.
