COLB RS485 BAUD RATE
Hello
please, which is the baud rate of RS485 on COLB?
Is it possible to choose it?
thank you
Diego
it's use by 9600bps, can't change by yourself.
(05-28-2022, 12:34 AM)admin Wrote: it's use by 9600bps, can't change by yourself.
ok , which way can I choose?
I need baud at 19200, please
thank you
it's fixed, can you change your deivce's baud?
(05-28-2022, 05:31 AM)admin Wrote: it's fixed, can you change your deivce's baud?
Unfortunately no, it's fixed too
do you want write program code on PC to send command by RS485 ?
(05-29-2022, 01:04 AM)admin Wrote: do you want write program code on PC to send command by RS485 ?
I have already written it for control air condition but I used Rs485 transmitter with variable baud possibility
settings are following
Baud Rate 19200
Bit stop 2
No Parity
thank you
let me check whether have a way.
(05-29-2022, 10:13 PM)admin Wrote: let me check whether have a way.
I will appreciate it
thank you
we have compile a BIN firmware file for you, that 19200 bps
.zip   AD_COLB_V1_1_13_220531.zip (Size: 41.91 KB / Downloads: 731)
