Help needed/wanted?
03-14-2022, 08:31 PM
you are welcome.
Hi, I'm new here and at raspi: Saw the new cool Server. Question: Can I install on this raspi all together, own MQtt Broker, Home assisatnt server and node red togehter? (in order to have really a local solution without need of cloud...)
I would love to use this server for Z-Wave, Zigbee and Sonoff devices to contol my whole house without and with Internet Thanks, Martin from Germany
06-14-2022, 10:44 PM
yes, you can install all software MQtt Broker, Home assisatnt and Node-Red on the KC868-Server, we have many video tour on our YouTube channel. if you want to use Zigbee and Z-Wave device, just connect with Z-Wave or Zigbee USB dongle with KC868-Server's USB port.
Hello
Unfortunately, it looks like I received a used product. (KC868-H32B) I can't access web settings. 192.168.1.200 (admin-admin) How can you delete all settings? (factory reset) THX
07-30-2022, 10:15 PM
e.) Hold on "Ethernet" mode button, when the [yellow and white and blue LED] all is ON, release it, then work mode in “TCP Server” and IP (192.168.1.200) by static mode;
here is details: https://www.kincony.com/how-to-use-kc868...oller.html i think you just need to use kincony scan device tool to find out IP address, your controller maybe in DHCP mode.
08-03-2022, 01:01 AM
OK. I managed to get into the web settings with the administrator password.
-I can't add the device on the android application. I do everything according to the video. https://www.youtube.com/watch?v=e5sHsjcY...dex=1&t=2s I'll make it this far-6:30 . Unfortunately, after saving, the hardware does not appear for me. (Conroller 32 Online) What do I do wrong? I have a UDP network connection. WAN setting. Not Wi-Fi.
08-03-2022, 03:25 AM
1. take a screen photo of your network setting webpage.
2. after added, you should go to "mine" - "device" - "Unclassified" , set a ROOM for controller.
Online Store: https://shop.kincony.com Alibaba Store: https://kincony.en.alibaba.com/ (08-03-2022, 03:25 AM)admin Wrote: 1. take a screen photo of your network setting webpage. Thanks. 1, I attached a photo 2, https://www.youtube.com/watch?v=yIVPCTmbKzg I created Floor and Room settings. -The yellow led lights up on the controller next to the power connector. -The red and blue LEDs light up next to the LAN connector. -I'm using a LAN. I can operate the device from a computer, but not from Android.
08-03-2022, 03:11 PM
I can operate the device from a computer? by which software? or just by webpage?
| 1 Guest(s) |
