Hi KinCony IoT,
Is it possible to reach the WebUI over Wifi in STA mode to manage the relays?
I can reach the webUI over LAN port.
Both Ethernet and Wifi are set to TCP-Server.
I was able to configure Wifi in STA mode and connect to my Wifi router. Then I disconnect the wired LAN port, but when I try to connect to the relay over the Wifi IP it doesn't give back the Relay Web UI, but the Wifi ESP32 config UI.
I would like to use HTTP commands over Wifi. Is it possible?
