10-14-2021, 06:33 PM
(10-14-2021, 02:29 PM)cris93ita Wrote:(10-04-2021, 12:04 AM)admin Wrote: Can you try the above arduino code? now we suggest use raspberry pi running Node-Red for alexa or google home. because sinric.com not free now.
Do you have any news about my problem with Alexa Routines?
thanks
0615721063Dth
Hello and greetings to Italy from Germany,
As of now the alexa module has problems since the service it was built on is no longer free of charge.
I suggest you use a raspberry pi with node red.
If you have problems with the setup i would make a video on how to set up everything from step one.
Otherwise i could also offer support via TeamViewer. I don't speak Italian but English is no problem. So of you want just tell me and ill show you what to do.
All you need is a raspberry pi and a sd card plus a sd card reader and the rest is a thing of about an hour to get everything running
Greetings from the cold Germany
