h32bs mqtt
hello...
first: ihave trying to connect kc868-h32bs to home assistant via mqtt
I followed this method:
https://www.youtube.com/watch?v=Yrat7hVzXRw
but i think its need to be updated because the mosquitto broker has a new way to configured
so can you plz update this section
second: where to found the new firmware version for h32bs thats compatible with mqtt.
thank you
1: the newest mqtt syntax of home assistant config yaml file, you can download at here: https://www.kincony.com/kc868-h32b-integ...-mqtt.html
2: i think you not need to update firmware, because the new syntax only just changed by yaml file, not need changed by hardware. if you want to update the newest firmware, here is the newest link of H32BS firmware download: https://www.kincony.com/forum/showthread.php?tid=2455
