COL - save setting and set temperature degrees
Hi, using COL daily to manage the whole house, I am noticing things that are annoying in the long run. every time I connect it starts with F as degrees reading and not C as I would like. with IFTTT when I program the "IF" condition and select the temperature sensor, I cannot put values with commas. for example I would like to put 20.5 ° C but ", 5" it is not possible to insert it. or 20 or 21. I buffered using the conversion to F and entered 69 but I don't think a solution .. thank you!
1. we will update COL PC software to remember "F" and "C" temperature setting in furture.
2. do you country use "," for decimal number? not use "." ?
1-ok thanks!
2-we use "," however if I write for example "20," or "20." after it does not allow me to add any decimal numbers.
2- OK, we will check when we have time, because these days in China is during new year holidays.
PC software update V1.0.407.0220 for KC868-COL and KC868-COLB logical controller.
user not need update firmware, only replace with new PC software package is ok.
download link: https://www.kincony.com/download/Kincony...7.0220.zip
V1.0.407.0220 improvement:
1. remember C/F temperature setting, re open the software will remember use C or F unit last time setting.
2. fixed IF condition temperature value can't input decimal number.
3. IFTTT debug information replace some character with < >, channel number ... etc
4. add remarks function for every IFTTT command, so that user can easy to understand every IFTTT command means
5. support use analog temperature sensor for AI port that range can use by "-" Negative temperature. Such as analog temperature rage from -20℃----+80℃
thank you very much, this update has fully solved the small problems of this post; )
(02-21-2021, 02:11 AM)admin Wrote: PC software update V1.0.407.0220 for KC868-COL and KC868-COLB logical controller.
These are very helpful updates, thank you.
James
